Rear Hub Wear
PostPosted: Sun Mar 18, 2018 12:46 pm
by DJR916
Hi There,
Am in the process of restoring my S3 LI150 - just removed the rear hub as part of the engine strip down.
Please can you advise, what the tolerance is for the thickness of the drum facing that engages with the brake shoes? mine does not look adversely thin, with no scoring but wanted to make sure it is within limits.
I cannot find anything in the Haynes manual - any advice is appreciated.
Thanks - Darren
Re: Rear Hub Wear
PostPosted: Sun Mar 18, 2018 2:48 pm
by Jono
Hi Darren
What makes you think you may have adverse wear?
Do you have a step in the Drum where the brake shoes have been coming into contact, thus giving a large step at rim.
Such an indication will normally define the if drum needs replacing.
Jono
Re: Rear Hub Wear
PostPosted: Sun Mar 18, 2018 2:57 pm
by DJR916
Hi There Jono,
Thanks for the reply - there is a step down which I would say is about half of the original thickness of the material - On reflection, I am mindful to replace as will be putting new shoes in (old ones look almost new but are contaminated with oil).
Thanks again - Darren
Re: Rear Hub Wear
PostPosted: Sun Mar 18, 2018 7:17 pm
by Jono
Hi Darren
That sounds worn to me and without seeing, from description I would replace complete with brake shoes.
Jono
Re: Rear Hub Wear
PostPosted: Sun Mar 18, 2018 7:38 pm
by DJR916
Thanks Jono and agreed - not worth messing around trying to salvage.
Cheers! Darren
Re: Rear Hub Wear
PostPosted: Sun Mar 18, 2018 11:32 pm
by rossclark
SIL hubs from Restos are decent and good value.
Re: Rear Hub Wear
PostPosted: Mon Mar 19, 2018 3:47 pm
by ToBoldlyGo
I once bought a SIL hub from SR. While it may have been strong it looked as if the spline had been peaned in with a bloody great chisel. Really crude stuff that put me off a bit.
Re: Rear Hub Wear
PostPosted: Mon Mar 19, 2018 8:06 pm
by DJR916
Thanks for all your advice guys!
Cheers -Darren
Re: Rear Hub Wear
PostPosted: Tue Mar 20, 2018 2:13 am
by Fast n Furious
There's probably little difference in the cost of a new hub compared to having the old skimmed by a reputable machinist anyway.
Re: Rear Hub Wear
PostPosted: Tue Mar 20, 2018 9:37 am
by HxPaul
I dont know if this applies to a worn rear hub with a lip as well as a rear hub that goes out of round but its worth a read viewtopic.php?f=10&t=8050&p=69759&hilit=skimming#p69759 5th post down.
