Early Cento rear hub bearing
Hi Guys, I'm looking for a little advice.
My 64 Cento engine is leaking gearbox oil into the rear brake drum through the hub bearing, (brake shoes are soaked and don't provide any stopping power).
It appears to have the early style bearing, which is supposed to be sealed, (mine has clearly failed), so there is no additional oil seal on the hub, and no space for one either.
The early type, 'sealed' bearing is available, from Lambretta Works USA. The later bearing (which I presume is narrower), the separate oil seal, and the later 'stepped' bearing retaining plate, are all available in the UK. Parts cost is about the same for both versions. why are those bearings so expensive ?
I believe that the clutch, gear cluster and layshaft will need to be removed to replace the hub bearing, and I don't have any of the special tools & pullers to do this.
May need to take it to someone who has the right equipment.
So. Is it really necessary to remove the gearbox to replace the rear hub bearing ? I've seen bearing pullers which can grip the inside lip of the outer race, to draw it out with the layshaft still in place, but they are very rare and that means pricy.
Once it's all out, is it worth changing to the later bearing and separate oil seal arrangement ? (the later type is supposed to be easier to replace the seal in the future).
Any suggestions would be much appreciated.
