LD Mk3 Mag Flange Removal
Hi All,
I have a LD Mk3 (57 / 58) that I need to remove a Mag Flange. The engine is out and striped as much as I can at the moment. I have heard that Mk3's are difficult to get off. So far I have:
Removed magneto cover and spring,
Removed the 19mm nut and washer,
Used the tool to remove / pop the flywheel off
Remove stator (x3 screws) and placed into the flywheel to aid me in not loosing magnetism on the flywheel unit.
Remove mag flange bolts (x6 small bolts)
Bent the locking washer down and removed the large nut, washer and circlip, so that I can now see the oil seal
Using a Stanley blade, cut into the mag flange gasket as much as I could around the edge of the outside of the casing
Placed my mag flange removal tool over the crankshaft end (GP / SX / LI fitted good and I just needed difference bolts!) and using three bolts, slightly bigger than the original ones used on the stator, screwed the tool on over the crankshaft and into the stator holes as far as they would go, to prevent thread damage on the stator holes when applying pressure to pop off.
Attempted to tighten to no avail. I have also used heat for 20 minutes around the mag housing area and tapping the side with a mallet to no avail. I have also used a long pipe for additional leverage on the tool to tighten it up and pop it off and ended up bending the very big bolt slightly with the force I used.
My thoughts now are perseverance and time. Over several days, leaving the tool on with pressure applied and on and off over the next week or two, continue heating up the mag flange area and using a mallet, taping at the mag flange around the side.
Any further thoughts would be greatly received.
Two images are attached to the post for viewing of the current state. Note: The holes used to secure the tool onto the mag flange ARE the stator ones!
Much obliged.......
Much obliged.......
