Conrod/Stroke
Hi Chaps
I'm finally rebuilding/assembling a 150 engine. As a relatively newby to the shaft driven motors of this age and following on from my earlier post on compression ratio's, some of the answers I got gave me some food for thought,
1. Some of you have fitted a stroked crank, what crank have you used? TV 175 S2/3?
2. Some of you have ported the heads/barrel, how much did you do and was the outcome worth it? (Iron barrel)
3. Some have fitted a Bantam D1 head, was it worth it?
As before, these are not rocket ships, its part of their charm, but I'm based in Gloucestershire and it would be nice to be able to climb some of the hills around the Cotswolds without some yummy mummy trying to mow me down in their 4x4.
I currently have a TV conrod to fit and have access to a press, but with fat fingers and my eyesight I kind of like to send it too somebody in the know to fit and true, the usual outlets don't want to touch them, who do you use?
