LD 150 mark 3 rear hub threaded rod
I sent a rear hub away for painting and the painter unwound the three threaded rods that the wheel rim attaches to. When I screw them into the hub they carry on threading through. Is this going to give a problem when the wheel nuts are wound on possibly onto a reduced thread. Do they need Locktite or do you just keep an eye on how far the rods go into the hub. I wondered if the bolts should be replaced with ones with a smooth central strip to prevent above. Comments welcome.
