model c gears / clutch causing engine cut out
Posted:
Mon Jun 06, 2016 9:46 am
by johncas
On my model c when I go to change gears there is like a crunch \ grind sound then engine cuts out the clutch leaver is sort of loose not tight is it the clutch is not engaging fully when leaver pulled in or is there some adjustments need doing
Re: model c gears / clutch causing engine cut out
Posted:
Mon Jun 06, 2016 2:07 pm
by jbcollier
Well, the first place to start would be to adjust the clutch properly. The clutch is adjusted at the engine first and then the lever freeplay is set.
Posted:
Mon Jun 06, 2016 2:38 pm
by jbcollier
