Rear wheel hub removal
Hi was wondering if anyone can help me I am just restoring a 1954 model e Lambretta but I have tried to remove the
Rear wheel hub but with no luck I bought a hub puller for the scooter shop on line which fit but the hub is not budgeing
Just keeps ripping the m6 bolts out I have retapped them still no luck I have tried heat on it and soaked in wd40 tried a puller on the nuts and now have snapped a bolt any ideas there is not a locking pin or anything is thereHi I am restoring a Lambretta 1954 model e 125cc and finding it hard to remove the hub to put new brake shoes on but it will not budge I have tried heat a puller and also Another type of puller but it just snapped the nut on the wheel is there anything else
That lock it can’t find much on this have a manual but does not give any info on this can you help any ideas thanks Andy
Sent from my iPad
Sent from my iPad
