GOLDEN SPECIAL
GOLDEN SPECIAL
Postby Covboy » Sat Oct 11, 2025 5:54 pm
I’ve just picked up this 1966 Golden Special originally from the Vicenza area
First job - a thorough deep clean
Re: GOLDEN SPECIAL
Postby Covboy » Sat Oct 11, 2025 6:09 pm
These were in the tool box
Re: GOLDEN SPECIAL
Postby dickie » Sat Oct 11, 2025 8:05 pm
Lovely that is.
I've got the same tax disc holder on my original paint s2!
Any special plans for it?
Re: GOLDEN SPECIAL
Postby Covboy » Sat Oct 11, 2025 9:15 pm
Apart from a deep clean my plan is to disturb as little as possible
I think the outer control cables are fine - still soft and supple so I won’t have to take off the horn cast to replace - I’m sure if I tried the fixings would shear.
Engine will get a full overhaul, exhaust looks solid
I’ll also try and keep it on 6V points ignition
The difference in paint colour is obvious- I think the original gold has faded to coppery pink in the sunlight and the bits that are still gold colour have been in the shade - all part of this scooters long history
Re: GOLDEN SPECIAL
Postby Storkfoot » Sat Oct 11, 2025 10:29 pm
Very nice. A lovely colour. :)
Re: GOLDEN SPECIAL
Postby Scooterslag » Sun Oct 12, 2025 12:35 am
Lovely, looking forward to seeing your conservation rebuild ;) Paul
Re: GOLDEN SPECIAL
Postby Covboy » Sun Oct 12, 2025 4:38 pm
Easy job this afternoon- washing the side panel with lots of hot soapy water
Quite please with the result
before
after
Re: GOLDEN SPECIAL
Postby Covboy » Wed Mar 18, 2026 1:28 pm
Bit of a mixed evening in the shed
This is definitely the first time this engine has been apart since new - 60 years ago.
The stator is impressively clean - I’m going to keep it on points.
Less impressive is the fact that the mag housing was seized in solid - I got a bit carried away and sheared it .(see my wanted ad…. :oops: )
Re: GOLDEN SPECIAL
Postby Cgt75b » Fri Mar 20, 2026 7:55 am
Hi,
Did that come from Rome Antiques?
Re: GOLDEN SPECIAL
Postby Covboy » Fri Mar 20, 2026 8:33 am
Cgt75b wrote:Hi,
Yes , lots to choose from there
Re: GOLDEN SPECIAL
Postby Toddy » Fri Mar 20, 2026 9:51 pm
I’ll have a look in the garage for a mag flange see what I have ;)
