Fast flow tap hi
Posted:
Sat Apr 15, 2023 7:10 pm
by Marrsy7
Hi all ! Hope I don’t sound to stupid here , I’ve bought a long range tank (fitted great) but I’m having probs fitting fast flow tap it’s to tight to push up into tank to nip nut up it’s ripped the gauze as I push it in is this a common prob ? I’ve fitted one before and had no probs , any help would b appreciated cheers
Re: Fast flow tap hi
Posted:
Sun Apr 16, 2023 10:07 am
by nickw
I've had problems with fitting taps previously on long range tanks. I have had to loosen the tank to move it within the frame to get the tap to fit. I have had similar issues with mid range tanks. Using a side exit petrol tap also makes life a bit easier and I think that is what I have fitted now. I'm presuming it is the engine mount that is getting in the way.
Posted:
Sun Apr 16, 2023 12:26 pm
by Marrsy7
Sorry I might have worded it wrong no I can get in to fit tap it just won’t push up into tank as if gauze filter is to thick it won’t go into tank it’s ripping gauze
Posted:
Sun Apr 16, 2023 3:31 pm
by nickw
LOl, I understand what you mean now. I've not had that problem
Posted:
Mon Apr 17, 2023 11:33 am
by Rich Oswald
The gauze tube should really go up into the tank very easily. Never heard of this issue before.
Posted:
Mon Apr 17, 2023 12:08 pm
by Storkfoot
The build quality on some of these tanks is pretty poor with sharp edges internally. I have had to take a round file and a dremel to the internals before now.
Posted:
Mon Apr 17, 2023 1:30 pm
by hullygully
I've had this same problem with my st/steel 18 ltre tank for years, no matter how & where I squeeze the filter it wont go up into the tank, sh*t workmanship, mine needs taking out & a drill shoving up it
, so I have to ride without the filter in the tap, no big deal really as there's a filter on the carb.
