Two jets in one hole
Posted:
Sun Oct 21, 2018 10:15 pm
by Knowledge
On my VHSH carb, the idle circuit has two jets in the one hole.
One sits in the bottom of the hole, and the other is the traditional location. The carb was supplied with a B45 at the bottom of the hole and a 60 idle jet.
Why two jets and why different sizes?
Re: Two jets in one hole
Posted:
Mon Oct 22, 2018 10:03 am
by ULC Soulagent
Taken from Mb’s tech site
Flat slide Dellorto's have another jet under the idle jet called an air jet! I find it best to leave it in as standard, some dealers remove it! There is very little information to what or how to adjust this air jet. Removing the air jet effects jetting!
Posted:
Mon Oct 22, 2018 10:57 am
by Knowledge
Thanks.
I can tell that was written by MB, as there are an excessive number of exclamation marks.
Does anyone have any other information?
Posted:
Mon Oct 22, 2018 12:15 pm
by Toddy
Its called an Emulsion tube i think it allows a smaller pilot to be used above it , some take them out and fit a normal size pilot im sure someone a bit cleverer will be along to explain better
Posted:
Mon Oct 22, 2018 1:59 pm
by dickie
Knowledge wrote:Thanks.
He's always surprised isn't he? Like that woman on the Catherine Tate show. Very helpful despight the appawling punctuation and grammar.
Posted:
Tue Oct 23, 2018 11:29 am
by ULC Soulagent
Contact eurocarb as that what I did when needing answers for the vhst flatslide that I was using.
Took them about a week too reply
