Simon_T wrote:Hi All,
question is if I change the slide I have in my 30mm phbh from 40 to 45 would this have a dramatic affect all through out the range and dan
gerously weak...?
It depends upon interpretation.
Although the slide affects the lower part of the range, from which point, in the upper range, the atomiser, needle, main jet & power jet (if fitted) take over in the upper range, any engine has to get through the lower range to get to the upper range & back down again.
If you get my drift, the lower range is, therefore, fairly critical.
Because a 40 slide is fairly common with all non-SH type derivatives of Dell’Orto’s utilised on Lambrettas, have you considered modifying what you have?
By removing material from the lower edge, a 40 slide can be converted to a 45, or even, say, a 42.5. Knowledgeable tuners, such as Taffspeed, used to carry out precisely that modification @ times.
Side by side comparisons enable measurement with a Vernier to calculate the amount of material to be removed.
(Do be aware that for the cost of a new slide, a brand new PWK with all likely jet kits can be purchased that some of us consider far superior…..)
