Starts without choke
PostPosted: Thu Sep 19, 2019 2:22 pm
by Knowledge
Most of the time, my scooter starts without using the choke.
Does this mean that the carb is over-fuelling through some other route, which compensates for the lack of manual choke? If corrected, could things be better?
I am running a 40 idle jet on a 30mm VHSH.
Re: Starts without choke
PostPosted: Thu Sep 19, 2019 2:38 pm
by St George
Could be that the choke is not shutting fully.
PostPosted: Thu Sep 19, 2019 3:02 pm
by Knowledge
Thanks, but it is fully shut.
The scooter runs well, so it is not as if the engine is struggling to run with a deployed choke.
PostPosted: Thu Sep 19, 2019 3:49 pm
by MickYork
Pilot too big ?
Any issues with hot starting ?
PostPosted: Fri Sep 20, 2019 12:34 pm
by Rich Oswald
I find that using choke is seasonal to a small extent. I use choke far less in Summer than in colder weather.
PostPosted: Fri Sep 20, 2019 5:42 pm
by Knowledge
MickYork wrote:Pilot too big ?
No
PostPosted: Fri Sep 20, 2019 5:43 pm
by Knowledge
Rich Oswald wrote:I find that using choke is seasonal to a small extent. I use choke far less in Summer than in colder weather.
Acknowledged. Perhaps I have just outted myself as a fair-weather rider.
PostPosted: Sat Sep 21, 2019 7:32 am
by Raveydavey
Mtech on mine has a mental curve so have the stator set to something like 25deg at tdc. I find I rarely need a choke.
PostPosted: Sat Sep 21, 2019 8:21 am
by Storkfoot
It’s petrol vapour that ignites. When the engine is cold, the petrol is nearly all liquid. You then need more petrol in the mix to get the % of petrol vapour needed to cause ignition. That’s why we turn the choke off as soon as it is slightly warm.
If you can almost always start without the choke, your mixture screw and/or pilot jet is providing too much fuel.
That’s what I have always believed.
PostPosted: Sun Sep 22, 2019 4:08 pm
by Knowledge
Thanks Paul. With a pilot jet of just 40, perhaps I will have a play with the mixture screw. At least I can do that without taking the carb apart.
Once the rain has stopped.....
PostPosted: Sun Sep 22, 2019 5:08 pm
by MickYork
Maybe a lot of scooters would start without the choke ?
I'd leave everything as is, if it's running ok.
PostPosted: Mon Sep 23, 2019 6:58 pm
by Hat
Depends how often I’m running mine. Anything up to 48 hours after my last ride i find it will start without choke. Anything longer needs it. Maybe there’s residual vapour in the carb or barrel that slowly leaches out?
PostPosted: Wed Oct 09, 2019 6:05 pm
by ROClarke
Hat wrote:Depends how often I’m running mine. Anything up to 48 hours after my last ride i find it will start without choke. Anything longer needs it. Maybe there’s residual vapour in the carb or barrel that slowly leaches out?
We just like to fiddle with them don't we.
Don't forget you are not running the original carb and running parts the scoot was designed for as well.
