Mikuni Overflow Leak
Evening chaps,
As per the title I've got a TMX35 that up until recently has been fine, however now every time I turn the fuel tap on fuel is leaking from the little overflow on the front of the fuel bowl.
Is this an easy fix like just bending the fuel float arms to lower the level or do I need to look at replacing the float valve tip or something?
This has also inspired me to actually fit the little plastic overflow pipes that I should've installed when fitting the carb (not thrown them away) - what size do I need please?
Cheers in advance, Ben.
