Mugello 198
PostPosted: Sun Nov 16, 2014 1:10 pm
by dave411
Hi all,does anyone run a 26mm Dellorto with a Mugello 198?
I have a remote filter,and will be using an Ancilloti exhaust.
Ball park jet settings?
Thanks.
Re: Mugello 198
PostPosted: Sun Nov 16, 2014 3:27 pm
by stonerosesmod
Hi,
Ran mine with
53 Pilot
AV266
X2 Needle on 2nd clip
115 Main
Ran fine with this with the Ancillotti
Neil.
Re: Mugello 198
PostPosted: Sun Nov 16, 2014 4:36 pm
by dave411
Thanks Neil,they are way off what came in the carb.
Re: Mugello 198
PostPosted: Sun Nov 16, 2014 4:40 pm
by dave411
When you refer to the second clip,is that from the top down,or the bottom up?
Re: Mugello 198
PostPosted: Sun Nov 16, 2014 4:44 pm
by stonerosesmod
2nd down from the top mate.Just do a plug colour check at cruising speed and again at over 3/4 to check the main jet
Re: Mugello 198
PostPosted: Mon Nov 17, 2014 5:18 pm
by dave411
Will do,but not quite yet,havent built the engine yet.One thing though,the main jet in my carb is onle a 100,smaller than the one you are using.
Re: Mugello 198
PostPosted: Mon Nov 17, 2014 10:37 pm
by stonerosesmod
Always start rich and work your way down to a safe looking plug.Id start off with at least a 110 main with the Ancillotti as every scooter is different
