26mm phbh on a reed valve 225 jetting advice
PostPosted: Thu Dec 25, 2014 6:28 pm
by camel
Hi,I'm scaling down the carb on a home tune reed valve mugello 225 from a 30 to a 26..has anybody got any 26mm carb set ups on a 225 reed valve motor they can share with me,weather its a rt,rapido,GT,ts1 dosn't matter at this stage
Cheers in advance
Camel
Re: 26mm phbh on a reed valve 225 jetting advice
PostPosted: Wed Jan 14, 2015 2:14 pm
by hullygully
the info I have is:- slide 45 / needle X2 / atomiser AV268 / pilot 50 / starter 50 / main jet - 110 (big bore) 120 (expansion pipe),
non of the above is with a reed block, but as with every carb you should do plug chops anyway as even similar engines can be different.
hope this info gets you close
