25 mm dellorto
Hi all,
I have just changed my inlet manifold to a shorter one and fitted a 25 mm dellorto carb which I want to connect to the standard air box using a GP flexible hose. (Previous owner had intended to drill out the side panel and fit a air scoop )
I chose the GP hose as it had the largest diameter hose openings but it's a bit big to couple onto the carb . Does anyone know of some sort of adaptor that will allow me to connect to the 25 mm phbh dellorto.
Jefft
Jefft
