jet 200 wont start when cold
Hi Chaps,
I have a Jet 200 that came with an open mouth 26mm Dellorto phbh with AF Rayspeed clubman.It will only start if I cover the venturi to act like a choke.I have now fitted a standard air filter and bellows to tool box.The jets are needle X7 pilot 50 tube V266 and choke or starter jet 70.If I turn the choke on when its running it bogs down slightly.I have sprayed easy start around joints when running but no effect.When it wont start the plug is not really wet as if it is not sucking enough fuel.Once running it revs ok .It is on a sorn so dont Know how it runs on the road.Looking on this site most suggest a 50 starter jet
Is a 50 starter jet bigger or smaller than a 70?
Does it make a difference that carb is tilted see pics?
I have not played around with float heights yet
Fresh fuel and carb cleaned twice especially the channel in float bowl that feeds starter jet.Jets blown out with compressor.Compression seems good.If I cover the venturi will start second kick.
If I cover the venturi completely when running it will stall.
Any ideas appreciated.
Thanks Grandpa.
Thanks Grandpa.
