Ts1 30 mm jetting ?
PostPosted: Sun Sep 24, 2017 7:15 pm
by steve chapman
Hi , I've just built a ts1 and I'm running it on a bgm box pipe ,
And a 30mm phbh , timming set at 19°, I was advised to set
Carb at 140 main , x7 second clip , av268 , and 55,Pilot
When I'm taking it easy it feels ok except a bit of four s
troking , but when I open it up if coughs and splitter but eventually clears , I tried an x13 on 1 1/2 clip and it does the same ,
Is the main a bit too big ? Or is it the needle ?
Any help would be good , thanks Steve
Re: Ts1 30 mm jetting ?
PostPosted: Sun Sep 24, 2017 7:31 pm
by col68
hi mate I run a 135 main with an x13 with an av266 with ram air fliter and a jl3 timing at 17 . hope this helps. col
PostPosted: Tue Sep 26, 2017 6:24 pm
by hullygully
Hi, be better to set your timing as a minimum 17 BTDC ;)
as for your carb, you need to do plug chops @ each 1/4 throttle setting to really find out where she's rich / weak & then alter your needle / jets to suit :shock:
PostPosted: Tue Sep 26, 2017 7:03 pm
by steve chapman
Thanks for your replys , the above settings where given to me by af , I keep getting conflicting ideas on the timming , some say 17 some say 19 ? , just wanted to get it close before doing plug chops, I've put a 135 main in tonight and seems loads better , so will do a series of plug cops over the weekend , thanks Steve
PostPosted: Wed Sep 27, 2017 6:30 pm
by ROClarke
steve chapman wrote:Thanks for your replys , the above settings where given to me by af , I keep getting conflicting ideas on the timming , some say 17 some say 19 ? , just wanted to get it close before doing plug chops, I've put a 135 main in tonight and seems loads better , so will do a series of plug cops over the weekend , thanks Steve
Be careful mate, I run a TS1 with a JL3 exhaust and got rid of the 4 stroking but ended up with a seize even though I did plug chops it had a weak spot at 50 mph which I was not aware of until finishing off running in after the last seize and had increased speed from 40mph to 50 mph.
Russ at Lincs Lambretta picked it up on his dyno and it has been a bugger to resolve, now I have the stroking back at low revs but have resigned myself it is the better of the two evils !
PostPosted: Wed Sep 27, 2017 7:46 pm
by steve chapman
Thanks roclark for the message , been out doing plug chops and at at 50mph in top , the plug does look light , not a nice Brown, so need to look into a bit more , steve
PostPosted: Sun Oct 08, 2017 5:13 pm
by steve chapman
I've been out doing a few plug chops and it is defernatly running lean at about 50 to 55mph , 1/4throttle , I have tried an x7 second clip , av268 55 pilot 135 main 40 slide , 19 deg timming and had a slight nip up , I also tried an x13 on second clip but it was very boggy , would backing the timming of to 17 deg help , any thoughts , Steve
PostPosted: Sun Oct 08, 2017 7:57 pm
by col68
Hi have you tried av266 with x13 on that clip . Have done a test for air leaks check inlet manifold front fixing ts1 air leaks there mate of mine found mine . He used a vacuum and pulled a sealer in to it . . col
PostPosted: Mon Oct 09, 2017 7:44 am
by steve chapman
I've just ordered an av266 so will give it a go , I'm using one of the reedspeed manifold and it didn't have a front fixing like std ts1 , not sure if anyone else has had problems 're air leaks ? Steve
PostPosted: Tue Oct 10, 2017 8:13 pm
by ROClarke
steve chapman wrote:I've just ordered an av266 so will give it a go , I'm using one of the reedspeed manifold and it didn't have a front fixing like std ts1 , not sure if anyone else has had problems 're air leaks ? Steve
I had air leaks on a new readspeed manifold, Russ at Lincs even struggled to seal it.
