Granturismo GT300LC info
Postby Eden » Fri Nov 07, 2025 7:02 pm
As ive not been around in the LCGB forum for a while i realised that the LC im now running has never been covered on here.
It first went on the road in 2019 in prototype form and to test it i took it to the Poland Euro and back. Since then its done many many miles and is still running beautifully.
Spec is:
Rotax 580 top end.
Purpose made GT case.
Unique Purpose made huge crank.
Aprilia RS125 ignition system.
Purpose made performance tuning exhaust.
3.8 final drive. (AF 5 speed, long 5th on 22X47 sprockets)
Underfloor scoop containing RS125 radiator.
Electric water pump.
RS125 guages.
Purpose made loom to cope with the Amps the RS generator pumps out.
Etc etc
Voice over video giving more info during on road footage returning from Porthcawl this year.
https://youtu.be/NQ9wdnUEclc
Its proved to be both reliable, easy to ride and very very quick.
Eden
Re: Granturismo GT300LC info
Postby jonoy » Fri Nov 07, 2025 7:36 pm
How much to build ?
jonoy
Postby Micky67keane » Fri Nov 07, 2025 9:04 pm
Just watched the video...'cruising' at 80!
Micky67keane
Postby Eden » Sat Nov 08, 2025 2:12 pm
jonoy wrote:How much to build ?
Short kit form is about 5k to build yourself.
Eden
Postby Mr G in NYC » Wed Nov 12, 2025 6:04 pm
Great bit of KIT , I have yet to do / complete a long trip on mine ,
so maybe Austria 2026 for its inaugural run !! 8-) :D G.
Postby Adam_Winstone » Wed Nov 12, 2025 11:09 pm
Riding this run with you guys was a lot of fun. Whilst all bikes ran well, Eden's LC was very different to our respective air-cooled motors. The ability to keep temps stable, and low, regardless of revs, speeds and duration is completely different to my personal scooter experience.
If you want a motor that can be held at motorway speeds from here to wherever and back, then this is in a different league. I've Euroed to Germany, etc on kitted motors but this is something else.
Adam
Postby jonoy » Thu Nov 13, 2025 6:26 pm
I’d love one but no knowledge to build it
jonoy
Postby Psychedelicropcircle » Fri Nov 21, 2025 6:19 pm
Be interested to know wot the air cooled evo266 was like. Are there many on the road?
Postby Covboy » Fri Nov 21, 2025 8:52 pm
What I find puzzling with all theses amazing engines (and in fact many of the more common kits) is the general lack of information provided from the manufacturers.
Given the total investment needed to get one of these on the road you would think there would be more data readily available
Postby Covboy » Fri Nov 21, 2025 8:54 pm
If only someone would write a book on the subject :shock:
Postby Knowledge » Tue Nov 25, 2025 5:41 pm
Covboy wrote:What I find puzzling with all theses amazing engines (and in fact many of the more common kits) is the general lack of information provided from the manufacturers.
What data are you after? List your requirements and let’s see if an owner or manufacturer are forthcoming.
(Yes, Sticky has written a book on most of the common kits)
Postby Covboy » Tue Nov 25, 2025 9:14 pm
Well for a start …. Set up with w ignition x exhaust and y carburation the kit produces NN torque and NN HP at ZZZZ RPM ?
Ie engine characteristics.
The RT manual is very comprehensive as an example.
Postby coaster » Fri Dec 05, 2025 2:10 pm
I've had the following:
Mugello 186 - limited build info
TS1 225 - No spec or build info but it wasnt bought as a complete kit tbf and plenty of info on forums
Avanti TT225 - Came with comprehensive build sheet plus phone support from Ron
GT240 - Extensive build manual supplied plus online and phone support from |Richard and Eden
GT200 - Same as above
Have to keep in mind that this is largely a cottage industry noy Honda or Yamaha
Users browsing this forum: Google [Bot] and 20 guests
