Covboy wrote:My standard GT240 with TSR evo didn’t miss a beat on the way to Austria
But was a bit thirsty in France - 8 miles to the litre but 10 miles to the litre on the motorway
If it ever blew up I’d probably replace it with a large RT kit
Also if your riding in a group I’d consider what kits they are using
Sharing spares means less to carry . 3 out of our 6 riders had Rt235s
At every stop they put in less fuel than I did
Having said that I’ll probably go on my GT186 next year. It’s made it to Italy before no problem
Nudger wrote:You'll blow a gasket over thinking this one & I'm the worst at procrastination...or am I?
My 2 cents is a piston ported RT195 or why not have your original 150cc barrel (assuming you have it) rebored to 175?
The options are endless but reading what you've put above, I'd try to keep it fairly tame for a long distance Euro.
Nigel. S wrote:Another vote for RT 195, 60/110.
lozmondo wrote:RT195 piston ported. 60 x110 crank, 30mm & vape ignition for my sx150
top end has done Adria, Libramont , Ayr & Ort inn Kries
Cant fault it, quick enough, torquey enough on a 5.00 final drive and around 12 miles per litre ,
Storkfoot wrote:The GT186 has got me to the Euros in Davos and Adria, and others. With an MB/bgm Clubman and a PHBH30, it pulls from low revs and will cruise at 60 plus with plenty of luggage on board. The GT186 was a joy to ride. I had it many years and miss it now. I never fitted an expansion pipe to mine but I did try a Ron Moss Avanti. I found that pipe better suited to the TS1 I had at the time. The MB/bgm Clubman was better suited to the GT186.
I never had a reed petal fail on mine, perhaps as I didn’t fit a high revving expansion. But do carry spares and Allen keys cut down to so has you can get access to the reed block without dropping the engine.
Spare pistons are pretty cheap and it is cast iron so a seizure wouldn’t necessarily be terminal.
The GT186 has a unique, or at least untypical, exhaust flange design. It stands proud to, I believe, allow better cooling. But, if you crack the exhaust uBend on a kerb for example, the sacrificial part is the exhaust flange and not the uBend. This happened to me in Italy in 2017.
That said, I’d still recommend the cast iron GT186 rather than lashing out in a new casing or using a nicasil lined barrel like a Casa or RT. I have a CST Stage 4 tuned 200 now with the same carb and exhaust. It probably beats the GT186 for top speed but it isn’t as torquey low down in the rev range.
steveg wrote:I don't mean this flippantly, but in my opinion you can use any engine you want as long as
It's tested and reliable
Can meet your expectations and match your riding style
Fits with the group you're travelling with
Take this year's euro as an example, our group all rode 225s, we mostly travelled on smaller roads and were generally sat at 50-55
When we had to use motorways we could sit at 65 and overtake as necessary. So it suited us.
On the same ferry going and back was a fella and his wife two up on a model d.
They rode on their own, made it there and back in the same time we did and probably never managed more than 45.
If you have enough time you can go anywhere you like on your Lambretta. But if your plan is Italy and back in 6 days you need
an engine that is capable of higher speeds for longer periods.if you've got two weeks 150 miles a day is doable on any engine.
Users browsing this forum: Baidu [Spider], TrackTen and 7 guests
