AF Uni easy clutch
AF Uni easy clutch
Postby gaz_powell » Tue Jul 21, 2026 8:42 am
I'm putting a 5 plate Reedspeed clutch kit in my next build and was going to use the rack and pinion out of an AF/Uni easy clutch but with a standard lever...
Ive got the AF kit on the shelf
Anyone done this?
My thoughts were the AF rack and pinion can only help the whole action.
Alternative is the Crimez but that's another expense and is the actual 2 piece mechanism any different, both fit in GP side casing and do the same job?
Re: AF Uni easy clutch
Postby hullygully » Tue Jul 21, 2026 10:17 am
I've got the reedspeed 5 red plates in mine, its soft, softer than my other two that have 4 red plates :o
Postby Norrie Bodge » Mon Jul 27, 2026 11:32 pm
gaz_powell wrote:I'm putting a 5 plate Reedspeed clutch kit in my next build and was going to use the rack and pinion out of an AF/Uni easy clutch but with a standard lever...
Anyone done this?
Gaz
my GP had this exact setup your aiming 4 last year & worked a treat m8
std clutch case arm & std type lever
i only swapped for a 6 plate setup when fitted the 5 speed box
Norrie Bodge
Postby gaz_powell » Tue Jul 28, 2026 6:52 pm
Ta
Users browsing this forum: No registered users and 60 guests
