rb20 touring
rb20 touring
Postby shamrockexpress » Sat Jul 04, 2026 5:56 pm
Anyone out there using an RB20 for touring/rallies etc.....with five speed box, if so what pipe/exhaust ???
i know from the endurance racing the RB20 is very reliable so i was thinking of building RB 20 kit, 58x 116 crank, 30mm flat slide dellorto, static bgm ignition, AF 6 plate road clutch, AF five speed box and AF RB Tornado exhaust........any opinions for swapping out the fore mentioned bits would be helpful, for the record i have all the parts mentioned.
Also what is the best small block casing for this, i do have an indian sil GP case ,,,,,,,,,,is there better???
Regards,
shamrockexpress
Re: rb20 touring
Postby bennn » Mon Aug 10, 2026 8:27 pm
Also interested in this - I've a RB20 engine already built with a Chiselspeed 'fast road' exhaust on it which is a bit hard work.
Considering trying a different exhaust in an attempt to bring the power lower down the rev range.
Cheers, Ben.
bennn
Re: rb20 touring
Postby shamrockexpress » Mon Aug 10, 2026 10:33 pm
I,m sure Mr. Scotty will be along soon hes probably busy racing.......
i would say a more restrictive exhaust would be beneficial.
shamrockexpress
Re: rb20 touring
Postby hullygully » Tue Aug 11, 2026 10:17 am
I remember dave stocks having this type of setup & I believe the kit was slightly de-tuned in order for it to be a tourer, still went like sh*t of a stick too 8-)
Re: rb20 touring
Postby Norrie Bodge » Tue Aug 11, 2026 12:52 pm
done a couple for mates
used the 60x116 crank tho as to tame the port timings down
no base packer & using a thick head gasket... they great tourers
Both used the 30 VHSH & Fran Supertourer pipe m8
Norrie Bodge
Re: rb20 touring
Postby shamrockexpress » Sat Aug 15, 2026 10:20 am
Thanks Norrie, unfortunately for me i have already got a new 58 x 116 crank i need to use up so is there anyway around this? maybe JL3 would help????
regards
shamrockexpress
Re: rb20 touring
Postby dickie » Wed Aug 19, 2026 7:12 am
Why not try a clubman?
The ex box st is available with rb stub. I think torbay lambretta have them.
Re: rb20 touring
Postby shamrockexpress » Thu Aug 20, 2026 10:28 pm
maybe an idea, i have two RB exhausts i will try before buying another.
thanks Dickie
shamrockexpress
Users browsing this forum: Baidu [Spider] and 24 guests
