New Rings Tricks?
PostPosted: Tue Apr 17, 2018 8:00 pm
by Granty
Troops -- Put new rings in the special - 200 Indian stage 4 barrel & standard piston -- already snapped 2 rings by getting them stick in the inlet port putting the barrel on, any tips with "easing the rings" past the inlet port when sliding the barrel on? Cheers G
Re: New Rings Tricks?
PostPosted: Tue Apr 17, 2018 8:14 pm
by CHRIS in MARGATE
Been there, done that amd screamed loudly. I find it easier to assemble the piston in the barrel first.
PostPosted: Tue Apr 17, 2018 8:32 pm
by Granty
CHRIS in MARGATE wrote:Been there, done that amd screamed loudly. I find it easier to assemble the piston in the barrel first.
Cheers Chris -- how did you get the rings past the inlet port and in the barrel & get the gudgeon pin through the con rod? for mine it looks like the rings will still be below the inlet port fitting the piston in the barrel when I put the gudgeon pin through?
Hope this makes sense? -- cheers G
PostPosted: Tue Apr 17, 2018 8:47 pm
by TS1-200
Sometimes you have to physically have to push the ring ends into the piston with a small scredriver so the piston moves past the inlet port
PostPosted: Tue Apr 17, 2018 9:02 pm
by Granty
TS1-200 wrote:Sometimes you have to physically have to push the ring ends into the piston with a small scredriver so the piston moves past the inlet port
Ah -- got it now - just couldn't see how this was going to work, I had already bolted the inlet on and then inserted the piston, understand now -- G
PostPosted: Fri Apr 20, 2018 1:22 pm
by bazza3004
Slip a thin feel gauge into inlet to assist rings over port edge
PostPosted: Fri Apr 20, 2018 1:25 pm
by Granty
Mission accomplished Boys -- thanks for all the tips -- G
