JET200 LIFETIME TANK or SUGGESTIONS
Hi all
following my recent excitement on the way to the C2C, I'm thinking about investing in a Jet200 Lifetime tank -
Does any member have any pictures of one fitted - I'm interested in the proximity of the petrol tap to the engine mount - I want a tank with lots of clearance, ideally with the tap located a bit further back, or higher , away from the mount.
The reason for this is because my last ( 2 month old tank
) was a 12L solid mount one, using the seat catch mount and air scoop bolts , but the petrol tap was almost hard up against the engine mounting.
Thinking about it, I must have knocked the tap when I took out and then replaced the engine. Due to the solid mounts, there is no give and I think this must have fractured the thread joint, only for it to give way completely
