Page 1 of 2
Miss fire???? Help.
PostPosted: Mon Sep 03, 2018 5:23 pm
by Jimmyjames
Hi all am I missing something here??
3 stators ,
3 cdi,s ,
MB + A Tambs ingnition system.
Still feels like it's missing at high revs.
Any help would be great.
Cheers.
Re: Miss fire???? Help.
PostPosted: Mon Sep 03, 2018 5:39 pm
by MickYork
spark plug ?
PostPosted: Mon Sep 03, 2018 6:30 pm
by Jimmyjames
:D no plenty of plugs.
PostPosted: Mon Sep 03, 2018 7:10 pm
by MickYork
HT cable
Suppressor cap
Broken/loose magnets in flywheel
PostPosted: Mon Sep 03, 2018 7:23 pm
by Jimmyjames
All have been checked and changed, flywheel changed as Well.
PostPosted: Mon Sep 03, 2018 7:59 pm
by ROClarke
Went down the same blind alleys with mine,turned out to head gasket.
PostPosted: Mon Sep 03, 2018 8:17 pm
by daniel whiteley
I had it once on my old Yamaha 125 lc turned out it was big end on its way out so on hi revs it didn’t run right due
To movement
PostPosted: Mon Sep 03, 2018 8:48 pm
by Jimmyjames
Big end bearing.
This was a new build only done 1200 miles , first issue I had was the mag race was loose on the crank.
This has been the start of the problem.
Send a than all new bearings .
The only thing not changed was the crank. :(
PostPosted: Mon Sep 03, 2018 8:58 pm
by Jimmyjames
Yes , causing the flywheel to run out of true and osolate .
Hitting the pickup.
Dame !!!
PostPosted: Mon Sep 03, 2018 9:01 pm
by MickYork
Flywheel bearing also a possibility
PostPosted: Mon Sep 03, 2018 9:07 pm
by Jimmyjames
Changed twice :oops:
There is small movement up and down when the flywheel is on.
This is normal??
PostPosted: Mon Sep 03, 2018 9:43 pm
by ULC Soulagent
No, get your crank checked for trueness
PostPosted: Mon Sep 03, 2018 9:47 pm
by Jimmyjames
Dame, if it's the only explanation I'll send it back to bgm. :evil:
PostPosted: Mon Sep 03, 2018 11:03 pm
by Toddy
Have you bypassed the loom maybe a bad earth in there somewhere damp ignition/ kill switch ?
PostPosted: Tue Sep 04, 2018 2:54 am
by Jimmyjames
No not tried that , what's the beat way ?
PostPosted: Tue Sep 04, 2018 5:48 am
by Toddy
Jimmyjames wrote:No not tried that , what's the beat way ?
Just remove the green from the cdi which comes from the loom this will bypass your ignition
And loom
PostPosted: Tue Sep 04, 2018 9:56 am
by Jimmyjames
Thanks Toddy.
PostPosted: Tue Sep 04, 2018 10:22 am
by Rich Oswald
Carburation problem?
PostPosted: Tue Sep 04, 2018 11:13 am
by Jimmyjames
Definitely not the ingnition bypassed as Toddy said still the same . :cry:
PostPosted: Tue Sep 04, 2018 11:56 am
by Norrie Bodge
Is it Ducati CDI’s you’ve tried ?
As the cheap matsuyami ones are crap & break down under load
