Silk purse from a sow's ear
A few years ago I was given a very knackered Spanish LI150 motor which has been lying under the bench waiting for its moment.
2019-10-30_07-53-33 by richardhenderson1968, on Flickr
20191026_153620 by richardhenderson1968, on Flickr
20191026_153629 by richardhenderson1968, on Flickr
Well, its moment has arrived. It is putting up a real battle, but I'm getting pretty good at tackling these awkward bastards.
Hub off without any real drama, but I doubt I can use these shoes again
20191026_160407 by richardhenderson1968, on Flickr
Used a 50 mm holesaw to attack the piston
20191026_163454 by richardhenderson1968, on Flickr
Then I poured 3 kettles of boiling water over the casing to loosen things up a bit. Somehow the barrel seems to have moved the first 1mm or so just from the heat, so it was pretty easy to remove with a little persuasion from a nylon hammer.
IMG-20191030-WA0006 by richardhenderson1968, on Flickr
The mag flange is putting up a good fight, but my will is too strong for it.
I knocked it 6 mm or so by belting the crank with a 2lb hammer and a few more kettles of boiling water. Then I had to add WD40, knock it back in and out several times. I thought the neighbours might be getting pissed off, so it got a reprieve but I'll get it tomorrow night.
IMG-20191030-WA0010 by richardhenderson1968, on Flickr
20191026_153629 by richardhenderson1968, on FlickrWell, its moment has arrived. It is putting up a real battle, but I'm getting pretty good at tackling these awkward bastards.
20191026_160407 by richardhenderson1968, on FlickrUsed a 50 mm holesaw to attack the piston
20191026_163454 by richardhenderson1968, on FlickrThen I poured 3 kettles of boiling water over the casing to loosen things up a bit. Somehow the barrel seems to have moved the first 1mm or so just from the heat, so it was pretty easy to remove with a little persuasion from a nylon hammer.
IMG-20191030-WA0006 by richardhenderson1968, on FlickrThe mag flange is putting up a good fight, but my will is too strong for it.
