Port timing calculator help needed
I'm trying to use the Lambretta Images Archive port timing calculator and I hope there's someone out there who can give me some clarification on a couple of the measurements:
First "Piston Crown to Top of Barrel at TDC": Is this the very top of the piston crown or the edge of the crown to side of piston?
Second "Piston height inlet side": Is this just the length of the side of the piston or does it include the crown?
And to confuse the issue even more could these measurements be to to edge of the top ring? I'm sure there used to be a calculator that all you entered was the deck height be that positive or negative and it sorted it all out for you but I have looked all over for it and cannot find it.
