Standard Primary Compression Ratio?
Hi all
I don't suppose that anyone has measured and calculated the standard 'factory' compression ratios have they?
The motors that might be of most interest would be 175 and 200, however, it would also be interesting to know of 125 or 150, if anyone has done so with these.
As with padding crank webs or fitting crankcase HPC plates, as per 60s tuning, there is a school of thought that this ratio is an important factor for efficient 'pumping' from casing into top end, particularly in the pre-expansion days.
The Honda 205 conversion was one that seemed to deliver higher performance than just cc and port timings normally delivered. With the shorter compression height piston, the primary compression ratio would have been raised slightly, increasing crankcase pressure and increasing speed of transfer process.
Anyway, this thread wasn't intended to start a debate over the pros and cons, rather, to raise the question of does anyone know what Innocenti worked to... as a datum for further consideration?
Cheers all
Cheers all
