Iron lined TS1 rebore clearance
I have just taken delivery of a 71mm Wossner piston modified for a TS1. The TS1 barrel is iron lined. The piston box states the piston is 70.96mm diameter and clearance 0.05mm which is 1.97thou. I seem to remember reading somewhere that for iron lined barrels clearances should be closer to 3.5 thou. I’m taking the barrel to be rebored at the weekend so any advice is gratefully received.
Also what sort of running in regime should I follow with an iron lined barrel?
