Close 5, clutch spider tightness...
So in out, in out move it all about, relieve the wishbone, shim the rear hub bearing (0.5)/layshaft (0.2) etc etc giving me an optimum 0.15 gear box endplate clearance, the clutch spider still seems too tight to me... Is it OK to loose the christmass tree to clutch basket shim (0.7)/ others available?
