Gori ignition kit
PostPosted: Sat Jan 24, 2026 12:54 pm
by superhooper
Hi peeps, are any of you using the Gori ignition kit? If so what are your opinions?
Super
Re: Gori ignition kit
PostPosted: Sun Jan 25, 2026 3:08 pm
by Knowledge
Why has the Gori ignition kit ignited your thoughts Super?
PostPosted: Mon Jan 26, 2026 10:58 pm
by superhooper
Cost compared to other kits. no pick up to fail. Earthing issues with vape & looks like even a simpleton like me could fit it.
PostPosted: Mon Jan 26, 2026 11:19 pm
by Knowledge
It is cheaper than the Casa kit, but more expensive than VAPE, based on my limited research.
Whilst the traditional six pole Ducati stator has LT coil and pick-up issues, whilst all others do not (as far as I am aware).
Is the GORI easier to fit? I like that fact that the GORI kit includes brackets but it appears that the easiest to fit is the Casa (no timing issues)
What concerns me most about the GORI is the four coils which look so similar to those on the Varitronic, which has a particularly poor lighting output (watts). Is the GORI output better?
A grown-up will be along shortly to answer some or all of these questions.
PostPosted: Sun Jul 26, 2026 1:59 am
by corrado
Did you go with the Gori kit?
PostPosted: Sun Jul 26, 2026 3:39 pm
by superhooper
No i ended up putting a rewired stator on. Unfortunately the flywheel broke in two half way to Austria! Doh!
