Can I bore out to 72mm?
I've got an iron linered TS1 that is bored out to 71mm. I have just ordered a new set of piston rings for it, but the piston to bore clearance is 4 thou. I know that is the normal clearance if it were a cast barrel but is it excessive for an iron linered barrel? If it is could I safely bore it out to 72mm and use an RB250 piston? The iron liner spigot thickness is 2.3mm, so that would come down to 1.8mm.
