AVANTTI REED SET UP
Right nearly there with the XL ,taking it to Taffspeed on weds for pre isle of wight set up. Avantti 70 x 60 ie 230cc, small reed valve mikuni TM24 , air filter in modded spanish air box and 42 mm u pipe on a standard tutu replica exhaust (no cone)
Also taking the chop engine 70 x 58 indian cast iron cylinder, avantti piston, 28mm PHBH big car air filter , ScootRS s/s system and a Ron Moss large head set to 9 to 1 comp. both run fixed electronic ign 18 degs btdc at the moment.
