Front sprocket set up
Posted:
Wed Jun 18, 2014 7:53 pm
by jonno
Need new front sprocket and matching thing,crush drive?,and front sprocket bolt.I have bought new from SR /camlam.I'm guessing these would be the best you can get.Or I have some slightly worn Innocenti ones,which would be best?
Re: Front sprocket set up
Posted:
Thu Jun 19, 2014 12:21 am
by Knowledge
The front bolt is becoming a difficult item to find, or at least a quality one. Having said that, the quality of this bolt has been an issue for many years - even Dave Webster makes reference to buying a six sided (rather than 12 sided) socket to use specifically for this bolt as the bolt head was always a bit iffy.
I keep an eye out for good ones at parts fairs, but I did see a guy selling them for about a tenner each at the last Wicksteed (ouch).
I think the trick here is to buy the best you can and carefully fit each component individually, and then in combinations, until you go for the final fit. If it don't fit, don't force it.
Posted:
Thu Jun 19, 2014 11:13 am
by Captain Pugwash
I don't think the old ones are iffy, maybe just a little shallow leaving very little for the socket to get a grip on.
Use a six sided socket but grind it flush so the socket sits better on the hex headed bolt.
Most sockets either six or twelve sided have a chamfered leading edge to help fit the socket more easily over the bolt, grinding the socket flush to lose the chamfer makes for a better grip on the shallow headed Innocenti drive bolt.
Same thing for removing hub studs.
This has been mentioned before on the old forum.
Posted:
Thu Jun 19, 2014 3:33 pm
by Scooter Paul
I'm pretty sure MB sells quality cush drive bolts.
Paul
Posted:
Fri Jun 20, 2014 1:25 pm
by Lammer205
Hi
I'm in work at the moment so if someone can tell me the socket size for this bolt so i can grind one down here , as i am doing a gearbox and sprocket change over the weekend! Thanks Lammer205
Posted:
Fri Jun 20, 2014 4:04 pm
by jonno
Bolt head is 14 mm.
Posted:
Tue Jun 24, 2014 6:12 pm
by robert gilchrist
I just bought front sprocket bolt from MB, & we'll pleased & also for ref, I got 6 sided wrench socket from B&Q my original one was well chewed from previous rebuild? To get the old one off I bought a set of wrench lock grips for taking off rounded or chewed bolt heads, great tool by the way!
