Problems fitting TSR on Series 2!
I bloody knew buying a viet pipe would end in misery!
It was this or a Franspeed for the gt186 and after a chat with Richard Taylor I opted for the tsr as he's heard of good results.
However, mines a series 2 and despite the listings stating that they fit series 1 2 and 3 it's blatently obvious that they are designed for the S3.
The exhaust hanger wont even go on the studs with a series 2 sidecasing without grinding which was no real hassle, it fits perfectly on my series 3 sidecasing though.
However, trying to line up the holes on the exhaust to the hanger? Not a chance, it's easily 15mm out, easily! There is no way this is going to fit, it's obvious though that if i had a ts1 / imola, using that stub which is shorter it would line up almost perfectly!
So, for me, that's £180 down the drain eh?
tsr1 by Donnie Canning, on Flickr
tsr2 by Donnie Canning, on Flickr
