22mm carb on a mugello 198
Posted:
Wed Mar 09, 2016 12:36 pm
by tottn15
Hi
I was wondering if you can run a Scootpia 22mm carb on a Mugello 198, it will have a Ancillotta exhaust as i want to keep it looking standard even with the panels off , I know it wont run to its full potential
thanks
Re: 22mm carb on a mugello 198
Posted:
Wed Mar 09, 2016 1:13 pm
by Rich Oswald
Why not try one of AF's 26mm reamed Jetex. Still look standard and will fulfill a lot of the kits potential. I have had two of them with great success, one on a 186 Mugello and one on a Rapido Classic 225,
Posted:
Wed Mar 09, 2016 3:24 pm
by tottn15
ok thanks
Posted:
Wed Mar 09, 2016 8:30 pm
by Granty
Rich Oswald wrote:Why not try one of AF's 26mm reamed Jetex. Still look standard and will fulfill a lot of the kits potential. I have had two of them with great success, one on a 186 Mugello and one on a Rapido Classic 225,
I run one of AF's 26mm Jetex's on my Stage 4 200 SIL Lump with a 42mm clubman -- Its a wee bit lumpy lower down but once into 3/4 throttle & above it goes very, very well. I'd recommend for sure too.
Posted:
Sun Mar 13, 2016 5:49 pm
by rexton270s
dont you think a 26mm is to big running though the airbox? i take it is anyway due to "standard looks"? can the engine get enough air?
Posted:
Sun Mar 13, 2016 7:58 pm
by Rich Oswald
rexton270s wrote:dont you think a 26mm is to big running though the airbox? i take it is anyway due to "standard looks"? can the engine get enough air?
As I said, I have run them on 2 bikes with undrilled airboxes with excellent results.
Posted:
Tue Mar 15, 2016 2:26 am
by corrado
tottn15 wrote:I was wondering if you can run a Scootpia 22mm carb on a Mugello 198, it will have a Ancillotta exhaust as i want to keep it looking standard even with the panels off , I know it wont run to its full potential
thanks
I don't see any reason why not. I'm planning on using one on an MB bgm 225 through the airbox with Scootopia "Ancillotti"
Posted:
Tue Mar 22, 2016 3:21 pm
by tottn15
thank you all for you help on this
