Kytronic experience
I have recently fitted a Kytronic to my TS1 (standard 225, Supertourer, Li150 box 46/16, PHBH30 with Ram Air filter through the panel). Now I have only, so far, managed 15 or 20 miles testing but I have a question.
First of all, my experience to date:
Dead easy to set up although, I checked the timing so many times, it seemed to take ages (strobed at around 2500 to 3000 revs). I have it on Curve 2 which retards from 25 to 17 (this is the only curve I have tried so far).
My initial run revealed it was running a bit weak somewhere around 1/3 throttle, I think. There was a little hint of pinking.
The highlight of this initial run was that the notorious "TS1 flatspot," which in my case was around 4200 revs, had gone.
For run 2, I changed from an AV264/x13 to an AV266/x7 second clip. Pinking now gone, running well and still no sign of flatspot.
My question relates to starting. In between runs 1 and 2 there was a couple of weeks but when I came to start for run 2, the first 5 kicks, say, felt like there was no compression. So much so, that I was just about to take the panel off and check there was a spark plug in
I didn't and next kick, there was more compression and it started. Now I understand that advancing the timing should ease starting but, is this feeling of little compression a sign that I maybe have it too far advanced?
