Is there anyway to upgrade front sprocket arrangement?
I'm experiencing front sprocket slippage on my TS1. I have replaced sliding dog and spring but not front sprocket as that looked okay. It's still slipping. The slippage is the one where it slips and then quickly picks up again. From my past experience, this is the front sprocket and not the clutch.
With hindsight, yes, I should have replaced front sprocket too but before I do that, has anyone successfully done a modification to eradicate this? Maybe a spacer?
I'm almost certain it's not the clutch as, whilst I was in there, I replaced that to the same spec it was before, a Surflex green 5 plate, MB springs, same thickness steels.
