TBH with the Avanti you could just "sling it" together and it would probably work well, it's a very forgiving kit.
I've "tinkered" with mine, taking it from 19BHP to just under 23BHP (all on a 4 plate clutch, with no issues). SIL GP200 gear box, 46 crown and the front sprocket changes between 19 and 20 depending on the exhaust.
I've used: a Ron Moss clubman, good power spread and pulls the hills smoothly.
Fransped Tourer Bit more umphh but with a few more gear-changes on the hills
Franspeed Race up and down through the gearbox, but when you hit the power band it flys, excellent on motorways (bit of a pain when it's hilly)
28 and 30mm phbh carbs, didn't notice any difference between them. Now running a 35 TMX Mikuni and got a bit more power and top end speed and a slightly slimmer wallet.
Used a Varitronic, static-timing and M-Tech ignition
The most conservative set-up got me 12 mile to the Litre and the most "extravagant" is about 8-9 mile a Litre. This all varies considerably depending on hills and wind.
One of the best set-ups I've come across is my mates. he was running a Rapido and we took the top end off and swapped it for the Avanti, got the squish right and it was on the road after about 2 hours. That was about 3 years ago and he has not had to do a thing to it. 30mm PHBH carb (not sure on the settings, it's what the Rapido was set at), same with timing, not sure on the G/Box but suspect he's got a 4.8 final drive, 4 or 5 plate clutch (he's not sure) nowt flash though and the chrome DJ exhaust......not sure where he got it or what make ?
It pulls well into the 70's fully loaded and it may well be an auto as he rarely changes gear. I followed him on the German Euro and going up some long hills I was changing gear every couple of minutes........his hand never moved !! I reckon I was changing gear 10 times to his 1.....
I'm just putting another engine together, this time with a 116 rod and a custom made exhaust........my hand has hovered over the "Buy" button on a Lectron carb.......but I just can't press the button
maybe in the future....
