Checking port timings
I am trying to check port timings on an RT195 kit but there are large discrepancies between my measured timings and the calculated ones, so I'm doing something wrong, just not sure what,
Measured using a timing disk and a 0.1mm feeler gauge to stop the piston
From exhaust port opening to exhaust port closing 171degrees,
From transfer port opening to transfer port closing 120 degrees
Calculated using lambretta images
1.9mm above the barrel, using gaskets as packers and a strong back, when the piston kisses the strong back measure the gaskets 1.9mm
Set the piston at the top of the exhaust port (using the feeler gauge) and measure down using a digital vernier and correct for gauge thickness, 40.1mm gives 164.25 degrees
Set the piston at the top of the transfer port (using a feeler gauge) measure down using a digital vernier and correct for feeler gauge thickness, 51.7, gives 111 degrees transfer timing.
I was expecting around 125 degrees transfer and 170 exhaust and the readings to be within a few degrees of each other.
can anyone help o advise what I'm doing wrong?
