Mugello 225 gearing
PostPosted: Sun Apr 09, 2017 8:31 pm
by mr mugello
Hi. My set up is a standard SX200 gearbox with a version 1 mugello 225 , 42 mm Ancillotti, 30mm carb. At the moment I have quick acceleration, but no top end, plenty of revs though, having to ride with 3/4 throttle position in 4th. 4th gear seems much too low. What would be the better gearing option if I was to tweak the gearing. Thanks
Re: Mugello 225 gearing
PostPosted: Mon Apr 10, 2017 6:17 am
by Toddy
People will ask What Front and rear Sprockets are you running ? so a Ratio can be worked out to suit rour set up
PostPosted: Mon Apr 10, 2017 7:24 am
by mr mugello
46 crown and 15 sprocket.
PostPosted: Mon Apr 10, 2017 7:27 am
by mr mugello
Just to add, all gears seem too low, engine seems like it is being thrashed. Petrol consumption is noticeably high.
PostPosted: Mon Apr 10, 2017 12:23 pm
by Toddy
Are you sure Your Clutch or your Cush Drive isnt slipping ??
PostPosted: Mon Apr 10, 2017 12:56 pm
by mr mugello
I don't think so. It pulls well even with pillion . Speedo is a bit wavy, but top end is roughly 65 .
PostPosted: Mon Apr 10, 2017 1:00 pm
by Rich Oswald
Go GP200 (Indian or Italian) with st'd 18/47 sprockets or even 19/46 with an expansion exhaust.
PostPosted: Mon Apr 10, 2017 1:26 pm
by mr mugello
Thanks . Would changing just my sprockets, but keeping my sx200 box be a workable option ?
PostPosted: Mon Apr 10, 2017 1:43 pm
by holty
ive just put your details in the gearbox calculator and your final drive ratio is 4.81 to 1 in top gear, if your engine pulls that easy with no slip of the clutch then i would try 1 tooth bigger on the front and see if it will pull ok, you might need a longer chain, depends how stretched the one you have on now is.
PostPosted: Mon Apr 10, 2017 7:30 pm
by mr mugello
Many thanks.
PostPosted: Mon Apr 17, 2017 3:02 pm
by corrado
Rich Oswald wrote:Go GP200 (Indian or Italian) with st'd 18/47 sprockets
If I'm reading the OP correctly then this would make it worst. Std SX200 gives 4.82 final drive, which OP thinks is too low, std GP200 gives 5.21. Sticking a 16 tooth front sprocket will give 4.52 which sounds too tall. Not easy to make a small adjustment with an SX200 box, next tallest jump to 4.7 = 16 x 48, then 4.6 = 16 x 47.
PostPosted: Mon Apr 17, 2017 8:27 pm
by Rich Oswald
Totally different gearbox though and this is based on what I ran on my version 1 Mugello 225
