Fuel Pump + float valve size with return loop?
Right guys (and gals),
So, I've been trying to set up a fuel pump to run with the 150 float valve and needle (VHSB) that some suggest is sufficient restriction to allow the carb to operate without the need for a pressure return loop to tank or tank side of pump. However, the pressure is still too great and I have not been able to eradicate it pushing too much through at tickover and low throttle openings. Once on the open road then the motor can handle any surplus and burn it off... or at least push it through.
Anyway, I've opted to change to the carb-side to tank-side recycling loop to reduce pressure but need to hear from those with experience...
Now that I've got a pressure return loop, do I stick with the 150 float valve or should I be increasing this to somewhere between the direct pump 150 and the normal gravity feed 300-350? What I don't want to find is that the return pressure release now leads to fuel starvation (!).
Your thoughts please?
Adam
Adam
