End can
PostPosted: Fri May 12, 2017 10:45 am
by Stevepshipley
Just noticed (it may have been happening for ages) the internal part in the endcan on my TSR evo spins a bit when I rev it. The part behind the big circlip at the back. Should I be worrying about this?
Re: End can
PostPosted: Fri May 12, 2017 11:13 am
by rossclark
Does suggest there might not be much wadding left in the can...
Has it got noisier recently?
Re: End can
PostPosted: Fri May 12, 2017 11:23 am
by Stevepshipley
Err, yes possibly. Should I take it apart and see? Only done about 1000 miles I reckon, why would it lose wadding.
Re: End can
PostPosted: Fri May 12, 2017 11:41 am
by holty
the wadding is usually fibreglass wool in it gradually gets burnt up and expelled out of the exhaust, ive got wire wool in my exhausts to stop this happening, bought a large bag of it from b+q :D
Re: End can
PostPosted: Fri May 12, 2017 12:05 pm
by Stevepshipley
Nice one thanks guys, does wire wool have the same noise deadening effect ?
Re: End can
PostPosted: Fri May 12, 2017 12:07 pm
by Rich Oswald
I have just replaced the wadding on my Taff Mk 4 (similar can) and mine spins but probably because the circlip was tack welded on and I had to dremmel it to remove it. Done quite a few miles since without detriment, in fact it probably uses the wadding more evenly.
Re: End can
PostPosted: Fri May 12, 2017 3:02 pm
by Toddy
This stuffs ok , don't pack it too tight though
http://www.ebay.co.uk/itm/181633559294? ... EBIDX%3AIT
Re: End can
PostPosted: Fri May 12, 2017 3:42 pm
by Stevepshipley
I'll try that then. Thanks chaps, sound advice as always
Re: End can
PostPosted: Sat May 13, 2017 7:59 pm
by Rich Oswald
Toddy wrote:This stuffs ok , don't pack it too tight though
Yhat's what I used
Re: End can
PostPosted: Sun May 14, 2017 2:25 pm
by gaz_powell
You need to sort it, I had this and left it for a while, eventually the movement cut through the tail pipe behind the circlip and the end came off with baffles etc flying out behind me on route to Llangollen last year (on A19 flyover.
Repack it and tack it the plate to the circlip.
I've just returned form C2C and mine on the Taff copy need doing as it spinning and rattling like a good en!!
Re: End can
PostPosted: Sun May 14, 2017 5:53 pm
by Mel K
https://www.scooterlab.uk/wp-content/up ... 796800.jpg
A get you home bodge for a spinning end can :idea:
Re: End can
PostPosted: Mon May 15, 2017 9:06 pm
by gaz_powell
gaz_powell wrote:You need to sort it, I had this and left it for a while, eventually the movement cut through the tail pipe behind the circlip and the end came off with baffles etc flying out behind me on route to Llangollen last year (on A19 flyover.
Stripped my end can tonight and the wrap was brittle and in pieces. Repacked it, alll good, just didn't have time to put a little little weld on the cap/circlip
Re: End can
PostPosted: Tue May 16, 2017 3:47 pm
by Stevepshipley
Stripped and repacked, relatively straightforward job for a lambretta. Many thanks thanks for the advice all. Cheers steve
