Air Filters/Ramair
Posted:
Mon Jul 24, 2017 6:56 pm
by Delboyli150
Hi Guys just looking for general census on Carb Filters,
Looking at putting a breath sweet filter on my scoot but wonder Is it really worth it in this country?
I have had one before but realised the side panel was squishing the elbow on the hose, therefore every time I stopped at a Junction I lost power pulling away, took it off and everything was running fine.
As I am booked in for a Dyno at weekend, looking for some answers.
What I have noticed on my new build is the elbow will not be squished this time, but has got me thinking is it necessary at all.
Will only be doing around 4-5000k a year. A Mixture of A/B roads.
Re: Air Filters/Ramair
Posted:
Mon Jul 24, 2017 8:57 pm
by missing lynx
whats your engine set up ? if you're thinking of putting a filter on you need to to it before you have it dyno'ed or any adjustments made at the dyno will need re doing once the filter is on
Posted:
Tue Jul 25, 2017 12:26 am
by peejay
Delboyli150 wrote:Looking at putting a breath sweet filter on my scoot but wonder Is it really worth it in this country?
i'm sure that road debris can be sucked into an open carb anywhere in the world!
if you don't mind excessive wear on engine parts then it's not a problem running without but it's something i just can't do.
Posted:
Tue Jul 25, 2017 1:19 am
by Fast n Furious
The induction roar you get with open mouth carbs on piston ported cylinders was cool, when you were young and daft. My girlfriend back then used to wear those Nylon socks called "pop socks" (remember them girls?) The fuel spitback from the carb used to melt the left sock off here foot. The amount of bollockings I got for that. Happy days.
I find the strap-on Ramair filter works really well. Makes a massive difference to how long a reed valve cylinder lasts. Doesn't limit performance, Easy to clean now and again and is cost effective to replace.
Posted:
Tue Jul 25, 2017 11:26 am
by Warkton Tornado No.1
Fast n Furious wrote:The induction roar you get open mouth carbs on piston ported cylinders was cool, when you were young and daft. My girlfriend back then used to wear those Nylon socks called "pop socks" (remember them girls?) The fuel spitback from the carb used to melt the left sock off here foot. The amount of bollockings I got for that. Happy days.
Absolutely agree with the sentiment but no knowledge (first hand) of Ramair
You can also read how some of us have covered similar ground under:
Tuning & Kits: new 200 set up &/or
Air filter options?I hope that helps.
Posted:
Tue Jul 25, 2017 11:36 am
by CHRIS in MARGATE
Put it this way. In France 2 years ago one of the guys got a piece of gravel jammed in the reed petals on his open mouthed TS1.
Posted:
Tue Jul 25, 2017 7:49 pm
by Delboyli150
Thank you guys.
I have realised I have opened a thread in the other forum as well, my apologies.. Think I will double check that the elbow is not squishing, if not I think I will take the Aifilter with me to CS and see what they say, if it is squishing I will give it a miss.
Once again thanks.
Posted:
Wed Jul 26, 2017 5:11 pm
by Delboyli150
WT1
Had a look at your thread 'Tuning & Kits: new 200 set up &/or Air filter options?' and a lot of information!
I think as mentioned before if I can get the filter on with no squish (Which seems to be the problem with a lot of these) then I will go for it.
If not WT1 where did you get your set up from? (The red one as shown in pic)
Just one more question! Honest!
Hypothetically if I got the scoot dyno with the filter on and say later on wanted to take it off (Losing too much performance) would I just need to change the Main jets? If so bigger or smaller to compensate for the more air?
Posted:
Wed Jul 26, 2017 5:17 pm
by St George
My 200 with a 22 carb runs fine until I fit the brand new large Ramair. Then it won't rev properly.
Posted:
Thu Jul 27, 2017 3:49 pm
by Delboyli150
Well Guys Placed the Air filter on today and it was badly squishing on elbow also forgot I have a mid range tank on so the foam was squished as well, I have measured the gap between the carb and the side panel and it is only 30mm which is 'Not a Lot!'
I will see what CS has when I get to the dyno at weekend.
