TS1 Port Heights and piston travel ?
Hi Guys
I don't have the parts I need to hand yet to check myself so I hope you can help.
I am planning an engine that will be using a TS1 225 top end with a 58 stroke 110mm rod. My intention is to lower the barrel in effect by using a thinner spacer under the barrel than the extra rod length amount.
MB suggests that having the piston level with the bottom of the transfers is a good idea for a touring tune but no port map that I have seen shows the dimension of the bottom of the transfers from the top of the barrel.
What I am especially trying to work out is if the piston will pop out of the top or not ?
