Iron liner for RB20
PostPosted: Thu Aug 17, 2017 7:19 pm
by Scooterdude
Ok ive inherited an RB20 cylinder from a recent rebuild as its damaged, im thinking along the lines of having it repaired by having an iron liner fitted. Is this even possible? and has anyone had experience of having this kind of work done + whats the expected cost? cheers...
Re: Iron liner for RB20
PostPosted: Thu Aug 17, 2017 7:34 pm
by Norrie Bodge
These did my spare TS1 barrel earlier this year -> https://www.pjme.co.uk/acatalog/Cylinde ... eving.html
i sent them a new piston & all done ready to fit for just over £200
PostPosted: Thu Aug 17, 2017 9:48 pm
by jonashford
take it to afs
PostPosted: Fri Aug 18, 2017 1:53 am
by Fast n Furious
Lining an RB20 might not be practical as the spigot is very thin to start with. You could consider a repair and a replate but at what cost compared to a new cylinder?
PostPosted: Fri Aug 18, 2017 8:46 am
by Scooterdude
Yes I had noticed the spigot is wafer thin, the more I think about it I don't think it would be a good idea.
The cost of rewelding/ ceramic lining is only about a fiver less than a new cylinder so not worth doing.
PostPosted: Fri Aug 18, 2017 12:55 pm
by Fast n Furious
Yes... Its the same with the 72mm cylinders. Use em, abuse em then make door stops out of them.
