Page 1 of 2
TS1 Kit
Posted:
Sat Oct 21, 2017 7:30 pm
by jonno
I'm going to run my newly purchased TS1 with a 30mm dellorto,and JL3 pipe. Anyone got some carb settings I can start with? Also info on the ring/bore clearance ( bane of my life atm lol) would be appreciated.
Re: TS1 Kit
Posted:
Sat Oct 21, 2017 7:52 pm
by johnnyjarvis
is it a vhsh ?
Re: TS1 Kit
Posted:
Sat Oct 21, 2017 10:14 pm
by jonno
No soz forgot to say phbh
Re: TS1 Kit
Posted:
Sun Oct 22, 2017 8:44 am
by col68
Morning mate I run the same set up had it set up on diablos dyno 55 idle av266 x13 2nd clip from top 135 main with a ramair filter 350 fuel jet . Runs cool on my egt about 440 degrees in mid range but fine on main jet . Do some plug chops to sure I have a nice dark choc brown at 1/4, 1/2 ,3/4 , and flat out. Hope this helps . col
Re: TS1 Kit
Posted:
Sun Oct 22, 2017 9:03 am
by Bogie
im similar 55 idle , av268 attomiser x7 needle 2nd clip down 136 main 70 choke and a 350 needle valve , runs sweet all through the rev range with no 4 stroking . as above though check your plug .
Re: TS1 Kit
Posted:
Tue Nov 14, 2017 11:11 pm
by jonno
With the carb manifold on the right where are pipes routing their cables,over or under the manifold?
Re: TS1 Kit
Posted:
Mon Nov 27, 2017 9:44 pm
by jonno
Couple of more things,wheres best to run the fuel pipe,is it under the frame near the bump stop,and is there a shorter choke cable available ? Ta
Re: TS1 Kit
Posted:
Tue Nov 28, 2017 7:16 am
by Knowledge
I make a shorter choke cable for TS1. £5 delivered. I accept PayPal, but will need your address.
What colour do you need?
Re: TS1 Kit
Posted:
Tue Nov 28, 2017 7:25 pm
by Fast n Furious
Recommend a piston to bore clearance of 0.05mm.
There should be a letter stamped onto the cylinder indicating the piston grade required to achieve this clearance..
The new ring gap should be around 0.28 - 0.29mm for a 70mm piston.
Consider fitting a new set of rings after 500 miles as the first set on a new cylinder gets some hammer as they strip the nickel deposit off the bore.
Don't be tempted to over-tighten the head nuts, as it will cause the cylinder to twist when hot resulting in an expensive seizure.
Re: TS1 Kit
Posted:
Sun Dec 17, 2017 7:58 pm
by jonno
Its a tight squeeze with everything on the right hand side. What are people using as far as carb filters go? Ive got an MB foam disc,which doesnt seem to go flat against the side panel,and a filter elbow which doesnt alow the panel on at all ?
Re: TS1 Kit
Posted:
Mon Dec 18, 2017 10:16 am
by roli150lam
You could cut a hole in the panel to fit a filter thru,or as many xo run it open mouth.
Re: TS1 Kit
Posted:
Mon Dec 18, 2017 10:18 am
by roli150lam
Cut a hole in the panel to fit a filter thru or as many do run without a filter.
Re: TS1 Kit
Posted:
Mon Dec 18, 2017 3:06 pm
by Feersum Injun
I believe LTH do a left hand manifold...
Re: TS1 Kit
Posted:
Mon Dec 18, 2017 8:09 pm
by Norrie Bodge
Feersum Injun wrote:I believe LTH do a left hand manifold...
yep, not cheap likes
https://www.lambretta-teile.de/Inlet-ma ... retta-TS-1
Re: TS1 Kit
Posted:
Mon Dec 18, 2017 8:31 pm
by jonno
Just got it all together so dont want to start taking it apart.......yet
I remember reading somewhere the fuel line has to be below the float bowl on Dellys,is this right? If I can move the banjo to the upright position it will help a lot.This will mean everything is below the bottom of the fuel tank btw.
Re: TS1 Kit
Posted:
Tue Dec 19, 2017 12:14 pm
by Feersum Injun
I know... but it's still cheaper than a new tank and repairing the existing cut out in your side panel...!
Re: TS1 Kit
Posted:
Sat Dec 23, 2017 6:33 pm
by jonno
Had some teething troubles getting it going.Noticed a black coating on the sides of the reed manifold coming away ,cant say I noticed it when assembling it.Also just like in the recent article in Scootering about barrel studs,I have the wear marks just where the studs are in the cylinder.Ive only started,tried to start,it a few times,is this part of the bedding in or signs of disaster ahead. The wear has removed the honing marks,as well as a few more marks in the cylinder.I checked the ring gap and its 0.33 mm and the piston gap is about 0.01 mm.
Re: TS1 Kit
Posted:
Mon Dec 25, 2017 7:18 pm
by Fast n Furious
The ring gap is fine but the piston bore clearance is far too tight. I suspect it may have been a bitch to put together?
Don't run it anymore.
Looks like you have the wrong piston grade for that cylinder assuming your measurements are accurate.
There should be a letter stamped on the barrel indicating the piston grade required. Ideally, (Though not comprehensively) the same letter should appear on the piston crown.
What have you got?
Re: TS1 Kit
Posted:
Tue Dec 26, 2017 1:31 pm
by jonno
Im going mad
Re checked piston gap 0.13 mm approx,feeler gauge down side of piston in the barrel.Earlier post shouldve been 0.1mm now 0.13mm. The piston is a B grade. I rang AF before I assembled it and they said about a thou clearance for the piston. Which is 0.0254 mm?
Re: TS1 Kit
Posted:
Tue Dec 26, 2017 2:20 pm
by jonno
