Muttleyoo7 wrote:I presently have a 12v AC setup on my GP and I want to change it to DC. I have bought the Sootronics DC stator, DC CDI and will get a wassel and battery. Currently I'm using a Broadhurst simplified AC wiring loom and AC ignition switch. Has anyone else done this and if so, how? and what else do I need to get before I start? Also can you get the SIP Speedo to work with DC power?
The MB diagram is fine for a standard 12v DC Wassel conversion but you are using one of Anthony Tams DC Ignitions so the wiring will be slightly different, hopefully Ant will have supplied a wiring diagram with it?
Re the SIP speedo, its the rev counter feed that has caused problems for users in the past as it needs an AC pulse. I connected mine to one of the yellows from the stator and it works just fine, over 2k miles and still going strong
Bit confused by the MB diagram tbh, why 3 batteries? I could understand if they are only very small ones but then one of them says 'battery tray'. The other thing is the fuse should ideally be in the negative leg as otherwise, if something shorts across the battery terminals, the fuse would not blow. Also, 15 to 20 amps is way too high, you wiring will melt with much more than 7 or 8 amps and then combust....I speak from experience
