Compression too high?
I have just built a 240 lump, it’s using a wiseco h2 piston, mugello/Monza central squish head, squish is about 1.1mm
It starts well but takes a real swing on the kickstart to get it over the compression stroke, I can literally stand on the kickstart and it won’t go past tdc..
I’m thinking compression is too high and as well as a pulled hamstring it’s going to end up with a hole in the piston.. any words of wisdom anyone can offer to support or debunk my theory or suggestions welcome..
