Li150 Special 1968 - Bent stand
Postby Big Al » Wed Mar 06, 2019 1:37 pm
When my scooter is on its stand, the front wheel is not off the ground.
I've seen mention of Sticky's suggestion on how to correct this. Can anyone tell me what it was please? I guess I need to put some sort of packing on the two lugs to stop the stand going so far forward.
Big Al
Re: Li150 Special 1968 - Bent stand
Postby HxPaul » Wed Mar 06, 2019 4:31 pm
I've got these stuck on the crossmember behind the stand https://www.ebay.co.uk/itm/2-STRIPS-STI ... Sw7aNcfkK4 Just cut off the large balance weights on the strips.
Postby Andyf » Wed Mar 06, 2019 6:45 pm
Don't the lugs on the stand sometimes get overstressed and bend over a bit?
Andyf
Postby Big Al » Wed Mar 06, 2019 11:24 pm
Thanks HxPaul. That sounds like a very good idea.
Big Al
Postby Fast n Furious » Thu Mar 07, 2019 1:41 am
Avoid sitting on your scooter with the stand down. This what usually causes it.
Postby Rich Oswald » Fri Mar 15, 2019 2:09 pm
Why would you want the front wheel off the ground, it just looks wrong imo.
Postby Hat » Fri Mar 15, 2019 4:31 pm
Front wheel isn’t supposed to be off the ground with the stand down, it should still be just in contact with tbe ground
Hat
Users browsing this forum: Google [Bot] and 24 guests
